Road King tire wear?
I'm new to Harley's. My front tire is almost completely worn out on my 2010 Road King, almost 11K miles. You can still see the full tread pattern. I could go another 500 miles I think. But the rear is still looking very good, about 3/16" of tread left. I had a friend say he goes through 2 fronts for every rear tire. Does that sound reasonable?
I never had a motorcycle do that. Hmm. I'm not complaining.
Don't EVER push the mileage on a motorcycle tire. Remember, you lose one at speed, you're in for quite a wild ride IF you can keep it upright. Front tire at 11k is pretty bad. As said above, I too go through multiple back tires before a front tire. Is the alignment ok on the bike? Are your front brakes dragging a lot? Things to look at.
Received 1,506 Likes
The rear tires should wear out faster as that's your drive tire. If you're doing a lot of front braking and not too much rear braking then the fronts may wear slightly more. I'd check the front tire if it turns freely when you spin it by hand. If not then that could be the issue as already said above.
Nevertheless, I'd change 'em now. Blowouts aren't fun.
Typically i go through two rear tires for every one front tire on my '09 RK. I average 12-15k on a rear and close to 27-30k on a front tire.
I can't really explain how your tires are wearing like that as it's opposite of what's normal in my experience. Obviously replace it since it's worn. Remember tire failures increase dramatically in the last thousand miles on a tire.
