slipon help
Old Mar 7, 2014 | 07:14 PM
snuffy75's Avatar
snuffy75
Stage III
Default slipon help
just installed a set of rush 3.5 slipons with a 2" baffle on a flhr. spoke with rush they recommend the 2.50" baffle for more sound and less heat. problem is no rumble from these....good at idle but when riding just a deep bass like humming sound. had rush on a fxdc and really liked them real loud and raspy also deep, but not like this. cant stand it. I know a lot of guys like this really deep throaty sound but this sounds like a car not a twin cam. rush did recommend also the big louie with 3" baffle. if I step this 3.5" muffler up to the 2.50" baffle and pull some of the packing off it will that help this sound out????
any help would be great!
Old Mar 7, 2014 | 07:46 PM
Geezr Glidr's Avatar
Geezr Glidr
Give it a few thousand miles, and the packing will burn off on its own. I've always gone with the 2.5 baffle, and they get louder with time. 2.5 baffle is definitely louder than 2.0.
Old Mar 7, 2014 | 08:39 PM
EG-2006's Avatar
EG-2006
Welcome to the site Snuffy. Stock head pipes will quiet the mufflers down quite a bit. True dual head pipes are much louder.
Old Mar 7, 2014 | 11:40 PM
DannyZ71's Avatar
DannyZ71
Or de-cat the stock headpipe. Also, get someone you trust to ride your bike while you listen to it as a bystander. You'll be surprised how different it sounds, and how good it may sound.
Old Mar 7, 2014 | 11:46 PM
SafetyMan's Avatar
SafetyMan
Raspy and deep are two different things.
I had 3.5" Rush with 2.0 baffles in them on true duals, loved the sound.
I now have 4" Rush Big Louies with 2.0's in them, and I love them. I had 2.5s, just too raspy, not enough rumble for me.
Old Mar 8, 2014 | 02:16 PM
snuffy75's Avatar
snuffy75
Stage III
thanks for the replies. I did pull the packing off the baffles today, actually did not seen to different some but much. definitely better though. I am surprised I thought I would of got a lot of popping and backfire but none at all.
Old Mar 8, 2014 | 02:20 PM
Buldozer's Avatar
Buldozer
If you don't want to wait for them to burn out you can always order a set of larger baffles and just swap them out. 5 min job to swap. I ordered a set one time that came with the wrong size in them, so I called them and they sent me the correct size and I changed them in just a couple minutes.
JHC210
2014-2024 Touring Models
Sep 6, 2016 09:46 AM
IMKMA
14
Aug 31, 2014 03:51 PM
ajay450
May 8, 2011 03:34 PM
maddghost
Jun 24, 2009 03:06 PM
snooper0069
Oct 11, 2007 07:16 PM
