04 electra shifter
Old Mar 26, 2014 | 04:59 PM
teflon's Avatar
teflon
Default 04 electra shifter
ok guys, just picked up an 04 elctra glide standard. seems to have a really loose shifter at all points (arms, shaft and at the tranny) what are the fixes out there to correct this? i think a can just tighten the arms, prolly replace the bushings in cross shaft, the one that concerns me is the arm on the tranny.... thanks ahead!
Old Mar 26, 2014 | 05:07 PM
Uncle Larry's Avatar
Uncle Larry
http://partsfinder.onlinemicrofiche....IFTER-ASSEMBLY
The Arm on the transmission shaft will require a bit of work ( remove primary ) If money is not object and you're not real mechanical look up betterlever.com ... Hope this helps.
And you can build your own trans linkage using heim ends also ... DO A SEARCH. Good Luck.
Old Mar 26, 2014 | 06:06 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
for the arm on the inner shaft,better lever.com,it will allow u to not pull the primary.i also replace the ball and sockets with hiem joints,the ball can rust and snap off.
Old Mar 26, 2014 | 06:44 PM
TWIN CAM 96's Avatar
TWIN CAM 96
LXM – LXF Rod Ends | Self-Lubricating Nylafiber MATRIX Race | Rodend Supply
This be what you need to finish your repair on that Standard (LXF5) x 2 5/16 x 5/16-24
Old Mar 30, 2014 | 06:46 PM
teflon's Avatar
teflon
any other suggestions folks???? its really loose and i have a feeling its gonna need some attn.
Old Mar 30, 2014 | 06:58 PM
vickers1's Avatar
vickers1
Those are all the suggestions. If you can't tighten the bolt and fix it, you either have to pull the primary and replace the lever or get the Better Lever like was suggested.
Old Mar 30, 2014 | 08:21 PM
CGLTD's Avatar
CGLTD
Better lever is expensive but a great product. Picked one up from his house in Norfolk a few years back
Old Apr 1, 2014 | 05:24 PM
teflon's Avatar
teflon
so it looks like better lever it is, anyone have issues installing it or ddi it go ok? i dont have a speed controlled dremel can i use a regular narrow do-more??
Old Apr 1, 2014 | 06:14 PM
Fathead2003's Avatar
Fathead2003
Being loose on the tranny is a common problem. I did what another member advised on my 03 three years ago . Replace the allan head bolt with a grade 8 hex head bolt. Use blue loc-tite and socket.
Old Apr 1, 2014 | 07:14 PM
bigdumbnoitall00
my indy ... when ever a new customers bike comes in loose or not he does the grade8 bolt trick cause he really hates changing them out, it will only work if the knurl is not too worn,if the lever has been loose for awhile the knurl will wear fast.
Rick04FLHT
Jul 5, 2013 08:24 AM
Biker90
Apr 14, 2013 03:53 PM
garcon
Mar 28, 2011 11:56 AM
maxum96
Apr 27, 2008 10:41 PM
zubaugh
Apr 26, 2008 01:25 PM
