Strange problem
Old May 5, 2014 | 02:15 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Originally Posted by Hammz
I'd guess a lean misfire. Check intake system for a leak, perhaps a vacuum tap open? If intake checks good, make sure contacts for O2 sensors wiring aren't corroded; clean & re-seat connections & ECM connectors too.
Dealer checked for leaks, and we also did that yesterday with the brake cleaner blast at the joints on the intake. ECM has been cleaned and re-seated a few times.
But the 02 sensors might need cleaning and a little dielectric added. Good thought. I don't know if the dealer did that.
I'm going over to his place tonight and we're going to re do everything the dealer did.
Old May 5, 2014 | 02:16 PM
Guntoter's Avatar
Guntoter
Sounds like a Crank Position Sensor.
Old May 5, 2014 | 02:29 PM
my67pnycar's Avatar
my67pnycar
Bad frame ground? That has been known to cause all kinds of crazy chit.
shooter5074
Would that do an intermittent error?
It does seem to only happen when the bike gets up to full operating temperatures. The first time I helped him with this, we had to ride for like an hour before it bumped.
Old May 5, 2014 | 02:59 PM
tater10's Avatar
tater10
sounds like a crank sensor
Old May 5, 2014 | 03:14 PM
shooter5074
That's 2 votes for the crank sensor. Easy enough to throw an O-scope on it.
That gets added to the list to check.
He better have ice cold beer, and pizza in his garage when I get there.
Old May 5, 2014 | 07:39 PM
shooter5074
Just got home from working on his bike.
Crank position sensor was fine
ECM connection was cleaned and dielectric added lightly.
TCA connector cleaned and dielectric added......... That's where things went south.
First run engine ran like crap....... re-seated the TCA connector, and got limp mode..... re-seated it again, and it ran OK..... re-seated it again and got limp mode again. Kept playing with it until it ran OK so he could ride.
The culprit is, it's a crap connector and needs to be replaced.
Old May 5, 2014 | 09:23 PM
Hammz's Avatar
Hammz
My conclusion is, it's a crap connector and needs to be replaced.
More likely a broken wire near the connector? Regardless, will probably need that wire/connector assy replaced to get a solid repair...
Old May 5, 2014 | 09:36 PM
user 8373900's Avatar
user 8373900
A friend has a 2011 Street Glide. When he's cruising along at 2500 RPM, in any gear, once in a while the engine "bumps". He describes it as if you have a momentary contact switch hooked to the ignition and tap it once in a while, so that it shuts off the engine for a split second. Sometimes it's one bump, other times it can be 2 or 3 in a row.
Sometimes the bump is so violent that it kicks off his cruise control.
It sometimes just does it once, then doesn't happen for quite a while. Other times it happens often. But always at around 2500 RPMs. His definition of once in a while is between 15 minutes and 45 minutes.
All of the connectors associated with throttle have been cleaned by his dealer, and dielectric grease applied. It's not gas, since it's been going on since last fall.
I'm thinking Throttle Position Sensor, but his dealer says they have never had to replace an Induction Module on a touring bike since they changed the design. I'm thinking they are wrong.
I told my friend that some of you are freaking geniuses....... don't make a liar out of me.
My prediction is the TBW (twist grip sensor) in the handlebar. It has a bad spot in it.
Mark
Well, there you go, guess I'm not Gypsy fortune teller!
Old May 5, 2014 | 09:39 PM
Hammz's Avatar
Hammz
Mark
Nope. It does it when the cruise is on. TBW is out of the control loop while using cruise.
