09 SG vibration fixed finally - crazy simple
I posted on earlier threads about an 09 96" SG with some mysterious vibration problem I was having.
After taking the bike half apart including the intake, primary + compensator, clutch + inspecting bearings and chain tensioner, changing plugs, gas, opening up the tank to check fuel lines and pump, adjusting the exhaust 20 times, running fuel injector cleaner, minutes away from pulling the cams and checking the crank, and just going out of my mind trying to figure it out... I finally found it.
Friggin spark plug wires. Trust me.... I feel like a fool.
Weeks of work and it was the stinking wires.
For whatever reason I never got a code (like cylinder 1 no combustion).
The bike never ran like it was totally missing and running on one cylinder.
There was just some heavy vibration in the 2100-2600 RPM range in the footboards and handlebars that was not there last season.
It would vibrate my feet off the boards and make my hands numb.
Bike would also surge and felt hard to keep steady while on throttle.
So I'm laying on my back just about to man-cry over this thing because I now think it's the crank and I'm too broke to fix it and I look up at the coil and for whatever reason pull the spark wires at the coil - nice and tight and sealed up - feels normal, and when I pull the front cylinder wire all the way off it literally fell apart with rust.
Coil still fires but the electrode is so corroded I'm sure it's not 100%. Looking for a stock coil now (anybody? anybody? ).
Anyway I'm running some new fancy SE wires now (because they didn't have stock in-stock) and the bike runs great. Really great...
Little hard to believe it was something so simple that I should have checked first thing...
Also a little hard to believe a wire will rot out this much on a bike with only 15k on it.
I can't see any way water was getting in there but obviously somehow it did.
So here is a pic of the wires and my ugly fake marble counter top. If you're going to go fake marble at least make it look nice you know? Rentals...
lp
lp
Seriously, If you havent done this yet, put some dielectric grease on both boot ends. This will keep any moisture out of the electrical connections. Should make it trouble free for a very long time.
