Head Temps
At about 55 MPH the CHTs will remain much lower because that is about the ideal combination of speed and RPM where the engine is shedding as much heat as its making, above or below it will climb higher.
ET and CHT is the same thing, front cylinder head OEM ET sensor. I'm not sure what the PV is reading as ET and CHT because there is only one sensor in the front head
I wouldn't try to draw any conclusions from IR temp gun reading at the spark plug, especially after shutdown, you can se why by looing at the first graph on the performance charts page I recently published on the website http://www.wardspartswerks.com/new-p...ance-data.html Actually studying the trends demonstrated in the data logged charts can help to explain a lot of what happens with CHTs during operation.
Conventional wisdom regarding Harley temps is mostly inaccurate, I've been studying this subject for several years now and I'm still learning new stuff all the time.
I don't know where exactly the PV is different for the temp numbers. I have an email in to Dyno Jet asking the same question as I cannot find an engine temp sensor in my manual. Could be overlooking it but.....
The fans turn on at 190 degrees. (using the included thermistor) When I shut down the fans run for about a minute turn off than run again for 30 seconds. Meaning my heads are not that hot at all. Even in 95 degrees the fans don;t run a long time after shutdown but always go off then come back on for a shorter time which is consistent with Wards Charts although mine is a 103 and his an 88.
I still only wonder about the fans drawing in hot air being so close to the heat of the jugs. I have put my hand behind the fans and the air blowing is hot across the heads. Much hotter than ambient temps
To double check my numbers, I decided to a quick ride tonight. I never got any faster than 55 and the temp was in the low 70s. According to the PV screen, my engine temp was mid to low 240s and my head temp was 320-330 degrees. When I got home, I grabbed my trusty IR temp gun and read the temps on each head at the spark plug base. The front was 279 and the rear was 326. These temps were taken within 1 minute of shutdown.
Currently, my setup is a 13 FLHTCU with a stage I. I am running a PV with the map that Jamie sent from Fuel Moto. I thought I was running an Auto Tune map but had never loaded on to my PV. I know that timing has a lot to do with temps too. Below is a picture of the AFR table. I've also attached the tune.
What are your thoughts?
ETA: I double checked my oil level just to be sure.... I am good at about 6 dots up from the low end.
