S&S super stock heads
I know an Indy in Mesa, Az. that swears by them. If you are going on a stock 96" the 79 cc will give 10.16:1 compression. On a 103" they will bump you up to 10.8:1. Both of those were with a .030 head gasket. A .040 head gasket on the 103" will get you back down to 10.57:1. They have pretty big intake valves which usually means a loss of low end performance, but not necessarily. The Indy I was talking about used them with an S&S 106 kit (4 1/2" stroker) on his '02 with S&S 585 cams and he can spin the rear tire by wicking the throttle.
I'm running the 89CC heads on a 106" with 583 cams. The performance boost was very noticeable. My numbers on a dyno were not as good as we hoped but the bike is out of tune. Got 86HP/97TQ. I'm waiting on a Mastertune so I can take it for a full dyno tune. I've since swapped my Big Shot for a Fat Cat and that made a big difference too. Everyone that's seen the build expected 10-15 more in each number.
The TQ line hits max at 2700 and stays above 90 out to 4800. That seemed to impress several people.
I think the heads work pretty well. Didn't go with a 30 head gasket. I haven't tried to spin the wheel but I do know it goes to 100 a lot quicker than it used to.
I'll share what happens at the tuner when it gets done. Hopefully by month's end.
S&S tech said if I want big tq I should keep the 551s and add 89 cc heads (to keep CR low), 58 cm TB, and regular SE injectors. S&S said that should deliver ~ 110hp/125 tq.
My numbers were probably a little off because I didn't adjust the calculator to reflect the stock compression before starting. Going with the stock '13 compression of 9.6:1 on a 103" using the 79 cc heads with a .030 head gasket will give final compression of 10.46:1. The same set-up with a .045 head gasket will give a static compression of 10.15:1. The '13 with the 89 cc heads and a .045 head gasket give a static compression of 9.26:1. It all depends on what you start with and what head gaskets you use. You will notice the higher compressions on each head require the use of pop-up pistons. The calculator is pretty accurate, but like any computer it just reflects the data that's inputted.
