2007 street glide dead
Old 07-11-2014, 03:05 PM
SuperTigger's Avatar
SuperTigger
SuperTigger is offline
5th Gear
Unhappy 2007 street glide dead
Hi All,
I have a 2007 Street Glide and the other day I started it after sitting for the night and it fired right up, and after warming up I got on and went to leave for work, got half way across the parking lot and it just died instantly no power at all no lights no alarm no anything. Has this ever happened to anyone else and what could it posibly be. I checkeed the battery and it was good, topped of the charge and still nothing, I've checked all the grounds and made sure they were tight and not corroded and called the local Harley shop and they couldnt help over the phone. Can anyone help Please.
Old 07-11-2014, 03:25 PM
Solex's Avatar
Solex
Solex is offline
just guessing but, How about the fuse or fuses ?
Old 07-11-2014, 04:22 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
You have a total disruption of power! There are very few things that can do that to you, one being the main fuse, if your bike has one, another is a broken main battery cable, or the main power wire to the ignition switch. It is probably a mechanical failure, in other words electricity cannot flow because something above has broken. A thorough inspection, starting at the battery, should locate it.
Your owners manual shows you where your fuses are. If you don't have one you can download it on the H-D website, go to the Owners tab.
Old 07-11-2014, 04:39 PM
SuperTigger
5th Gear
I did check the fuses and all were good and this weekend I will do just that and work my way from the battery out through the whole bike and see if i can find anything out. Thank you all for your input and if there are any other suggestions I'm open to them all. Again thnk you!
Old 07-11-2014, 07:08 PM
2-Piece's Avatar
2-Piece
2-Piece is offline
Defective or loose connection to the main switch on the steering head?
Old 07-11-2014, 08:20 PM
SuperTigger
5th Gear
I will also look at that main switch tomorrow thank you for your suggestion.
Old 07-12-2014, 09:46 PM
SuperTigger
5th Gear
Well I tore the whole bike down and found nothing that i could have tightened or any cut wires that may have shorted out the bike so if no one has any other suggestions I'm just gunna take it to Harley.
Old 07-12-2014, 09:50 PM
Wanna Ride's Avatar
Wanna Ride
Wanna Ride is offline
Did you ohm out the ignition switch? I've seen this happen and it completely interrupts all power.
Verify that you have 12vdc into, and out of your switch. I'm betting you don't, if you don't hear your fuel-pump energize.
Have you done ANY work to anything recently? Anything in the fairing, stereo, bars, lights, etc?
Veekness's Avatar
Veekness
Veekness is offline
Best move you could make at this point, actually!
Old 07-13-2014, 12:57 PM
SuperTigger
5th Gear
I didn't OHM the ignition but I did take the ignition apart and I didn't visually see any problems and no i haven't done any alterations yet.
Quick Reply: 2007 street glide dead
