Hesitation and PO codes question
Posted this in the tech section, but thought there might be a little more traffic here.
2012 RGU with stage 2, Andrews 222, de-catted pipes, Power Vision. Bike will hesitate sometimes, seems like sometime when I am off the throttle at slower speeds/rpms, when back on the throttle it hesitates and sounds like it's not getting enough fuel or air (to me feels/sounds more like getting choked off from air). If I roll the rpms up it runs right. Codes are PO132 (too rich front O2 sensor) and PO134 (front sensor not working). I have had it checked at dealer (still under warranty), they can't find the problem, say it isn't the sensor. Any ideas? I am going to:
1. Check exhaust for leaks, loose gasket.
2. Check and clean filter.
3. Run auto-tune and apply new tune to see if it fixes.
4. If that doesn't work, load a pre-loaded tune in for bike (currently running an auto-tune).
I have tried all this before except number 4 and seems to fix for a while and then issue comes back.
Wonder if anyone has had similar issues and resolved or any ideas. Thanks in advance for any input.
https://www.hdforums.com/forum/ignit...admin-157.html
First thing they/I will want to see is the tune file that is currently in the bike.
Jrotten65
17
01-26-2022 08:34 PM
