Twin Cam Engine Short Block - Cases with Crank, Rods, Wood Cams
Up for sale is a 2007 Twin Cam A short block assembly removed from a 2007 Street Glide at about 22K miles. The engine comes with the crank, rods, lifters, stock oil pump, Wood TW-8-6 cams. Torrington cam bearings, stock cam plate, cam cover with skull plate, lifter blocks. Stock TC-96 cams are available if wanted (not pictured; they were removed when new, so no wear).
Should fit 2006 and up Dyna, and 2007-2016 Touring models. Do your own research as to fit, etc.. I can help but ultimately you need to make sure it fits your application.
Rods rotate well with no sticking and no excessive play. Rod ends look great.
I pulled this engine from my 2007 Street Glide when I installed a 120R.
This would be a great base to either restore an engine or for a performance platform.
$1300 + shipping (likely to be $100 - $180). I may be able to do better on shipping, though this seems to be the going rate for engines sold on eBay.
fuelmoto
Milwaukee Eight (M8)
17
11-25-2023 03:03 PM
VDeuce
06-11-2019 03:02 PM
slvrscoobie
Stock Harley Take Offs
07-20-2017 07:46 PM
