M8 Cam Install Step by Step **UPDATED w/New Images**
In this article we will outline what is involved in a cam swap in the H-D Milwaukee Eight engine. This is a very straight forward procedure. We will be covering the complete step by step install using a bolt in replacement cam using quick install adjustable pushrods, in this example we will be re-using the stock lifters. The bike is a Road Glide with 107" M8 air cooled engine.
Here is the motor ready for disassembly, we've removed the complete exhaust system, air cleaner, and cam cover.
In this application we will not be re-using the factory pushrods, we are using Quick Install style adjustable pushrods. THe image below shows cutting the factory pushrods with a bolt cutters and removing them. Do not use a cutoff wheel or grinder, use a bolt cutter which makes a clean cut and eliminates (or highly reduces) the chances of any particulates making their way into the motor.
Remove the cam cover. Here is a close up image of the camchest. Next remove the cam chain tensioner, sprockets & chain, then completely remove the cam plate leaving the oil pump in place in the engine case.
camchest with cam plate removed
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
M8 cam plate removed from engine
backside view of M8 cam plate with camshaft
cam chain tensioner
stock H-D M8 cam on the left, Wood Performance WM8-222 cam on the right. Note the lobes are pressed on the factory cam, the aftermarket cam is machined from a billet blank.
Carefully clean & inspect the cam & cam plate, liberally apply assembly lube to the camshaft
Replace o-ring on feed oil port, install cam plate into the engine cases, install screws loosely
Use rear wheel to roll engine over to ensure the oil pump does not bind. Tighten cam plate screws in sequence according to manual, do not final torque. Turn engine until the flat surface on the crankshaft is horizontal. Carefully torque cam plate bolts in steps as listed in service manual. Final torque on these bolts is 120 in-lb
Note cam timing marks. The dot on the upper sprocket will be at 6:00, the dot on the lower sprocket is at 12:00. Install tensioners, use blue loctite and final torque is 120 in-lb
Install pushrods and follow the full adjustment procedure. Adjust pushrods to spec based on the thread pitch listed by the manufacturer and for the specific lifter you are using.
Install cam cover, you are now ready to install the exhaust system and other components that were removed for cam installation
