M8 Cam Install Step by Step **UPDATED w/New Images**
Old Feb 9, 2019 | 06:04 PM
Bumpandrun's Avatar
Bumpandrun
Originally Posted by GlidingJoe
Stych listed a part number 25566-06, that is the Gear Drive Retention Kit which are the Sprocket Bolts, (which should be replaced as well) The Cam Spacer Kit # is 25928-06.. Just a heads up if your ordering.
bought them yesterday and only 6 bucks! Lmao.....too cheap not to do
Old Nov 22, 2023 | 09:56 AM
BiggDeesporster's Avatar
BiggDeesporster
Default Cleaning
What do you clean the oil pump with before applying the assembly oil?
Old Nov 24, 2023 | 07:27 PM
Sparkules's Avatar
Sparkules
RE: Ordering the upgraded pump kit with the updated housings, new design scavenge gearotor, rear seal. The Tech Bulletin shows a feed gearotor as part of the kit, the parts microfiche show the pump kit number, then “also order …….. “. This “also order” is the feed gearotor part number. So, does the kit 62400247 come with both the new scavenge gearotor AND a feed gearotor ? If not, just reuse the existing feed gearotor? Looks to me the feed gearotor is the same part number not superseded.
Old Nov 25, 2023 | 08:56 AM
Tharber's Avatar
Tharber
It would be nice if FM included push rod tubes with their cam kits.
TH
Old Nov 25, 2023 | 10:04 AM
Fireball Jack's Avatar
Fireball Jack
TH
Do their push rods need them?
Old Nov 25, 2023 | 10:10 AM
bradsULtd's Avatar
bradsULtd
Kit P/N 62400247 includes:
p/n: 62400126 Gerotor Assy, Feed
p/n: 62400238 Oil Pump Assy, Oil
p/n: 62400245 Oil Pump Assy, Cover
I don't think these p/n's have been superceded and are still accurate...
Old Nov 25, 2023 | 01:46 PM
Mchad's Avatar
Mchad
Nope. Using them in two bikes. Twin cam and M8. No issues with stock tubes.
Old Nov 25, 2023 | 03:03 PM
MCRD'71's Avatar
MCRD'71
Originally Posted by fuelmoto
We put together an updated Cam Installation article for H-D Milwaukee Eight engine, the previous thread we posted back in 2016 no longer has images due to a server hosting issue. The full article can also be found on the Fuel Moto University site along with other technical write ups.
In this article we will outline what is involved in a cam swap in the H-D Milwaukee Eight engine. This is a very straight forward procedure. We will be covering the complete step by step install using a bolt in replacement cam using quick install adjustable pushrods, in this example we will be re-using the stock lifters. The bike is a Road Glide with 107" M8 air cooled engine.
Here is the motor ready for disassembly, we've removed the complete exhaust system, air cleaner, and cam cover.
In this application we will not be re-using the factory pushrods, we are using Quick Install style adjustable pushrods. THe image below shows cutting the factory pushrods with a bolt cutters and removing them. Do not use a cutoff wheel or grinder, use a bolt cutter which makes a clean cut and eliminates (or highly reduces) the chances of any particulates making their way into the motor.
Remove the cam cover. Here is a close up image of the camchest. Next remove the cam chain tensioner, sprockets & chain, then completely remove the cam plate leaving the oil pump in place in the engine case.
camchest with cam plate removed
NOTE! The cam chain tensioner uses #27 Torx bit.
Old Dec 17, 2024 | 10:14 AM
jake24lt's Avatar
jake24lt
Camshaft alignment tool?
Old Apr 25, 2025 | 04:13 PM
early times's Avatar
early times
Pay close attention to all your o rings, use plenty of assembly lube.
