Mark this thread as Unsold
Screamin' Eagle High Capacity Oil Pan
A great addition to a high-performance motor, or for the rider that tours in extreme temperature conditions, the Screamin' EagleŽ cast-aluminum oil pan is designed to increase the oil capacity by 1.5 quarts over the Original Equipment pan. Increased capacity means the oil cycles through the engine less frequently and the oil can remain in the pan for a longer period of time. Cast-in internal baffles manage the flow to the oil pickup, and keep the hot oil exposed to the heat-conducting ribbed aluminum sump. The oil pan comes with a set of new gaskets and the gasket sealant required by the instructions which are also included. This oil pan is like new only use for approximate 1000 miles...
Fits '09-'16 Touring models. Does not fit with Oil Temperature Gauge - Does not fit Trike models.
Asking $385 Shipped
Asking $385 Shipped
The oil pan is just too wide to work with my electric center stand. To me my center stand is more important.
