RIGHT LEG HEAT and HD CoolFlow fan
CoolFlow Fan
Part Number 26800128I am looking at the CooFlow fan. Not interested in any other heat reduction schemes, at this time. I have read the user reviews and most are 5 * with the worst being 3 * and even there, the user was unsure if the auto-function had failed or it just was not hot enough. But 10 of the reviews were 5 * with loads of kudos.
Having said that, I am inherently suspicious of reviews.
I studied the fan when I first got my Trike since my wife was complaining about heat. I could not find much of a path for the heat to exhaust to. I was also told by a dealer that they did little to re-direct the heat removal path.
So, has anyone here installed the CoolFlow fan? Results? Satisfaction?
SpringerRider (05-01-2019)
Same here. I've had the the CoolFlow fan since my 2018 was ridden away from the Dealer when new. So, I cannot compare before and after. My experience all summer was that my wife never complained (about heat) from the bike. The fan stays on Automatic and does an adequate job. Much cooler than my last two wheeler FLHTK.
Verify that fan is turned OFF before starting the engine. Under certain circumstances, an errant diagnostic trouble code may be set if the engine is started with the fan in the ON or Auto settings. Clear the code.
Is this true? I would prefer to put it in auto and forget about it. Also, I see they are using a toggle-switch. That switch will not match any existing switches.
I would prefer to wire it into the Original Equipment fairing dash panel switch. Has anyone done it that way?.
