How well do your rear brakes work?
The rider safety programs used to say that on a motorcycle, 70% of your stopping power was in your front brake. I believe that on a trike at least 70% of your stopping power is in your rear brakes. It makes sense to me that you have much more tire surface area in contact with the pavement on the rear than you do on the front tire. I primarily use my rear brakes and the trike stops very well.
Hogdoc45 (03-16-2017)
msocko3 (03-16-2017)
I agree with Sloufooot. Harley must have had a reason to upgrade the rotors and pads. I've never felt that the rear brakes on my '13 have worked well since I bought it new. And, the emergency brake on mine is useless. Got to say that I have not spent the time to adjust it properly, I just park where I don't need to use it.
I don't usually disagree with things you say, Casper, but, in this case, I do. I can very easily lock up the front tire on my trike with very little effort. A firm steady push on my rear brake pedal stops me in in short order. I have learned that a steady push on the rear pedal coupled with a feathering pull on the front lever stops me (in my opinion) best.
Ride safe my friend
