Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Change Out Ultra Triglide Front Wheel for Freewheeler 19 inch size?
Old 06-12-2019, 10:54 AM
arnie54's Avatar
arnie54
arnie54 is offline
I have a 16 triglide. I purchased the chrome freewheeler wheels & installed them. I see no difference in ride or handling. I have had 2 triglides before this one with the stock 16" wheel. Just throwing that out there so you know I have had experience with the stock 16'' wheels. I have a lil over 30,000 miles on this trike with the 19" wheel, & I would do it again.
The following 2 users liked this post by arnie54:
ghostrunner (06-12-2019), TOHOG (12-02-2019)
Old 11-30-2019, 07:42 AM
Cherch's Avatar
Cherch
Cherch is offline
I have been thinking about adding the enforcer chrome wheels from harley on my 2019 triglide. the 19" front wheel has anyone kept the stock front fender or did you go with a modified front fender?
Old 12-01-2019, 08:18 AM
TOHOG's Avatar
TOHOG
TOHOG is offline
I went for the 19” from HD om my 2018 Tri-glide. Changed to the entruder mags. Difference is a bit easier steering in the twisties. Looks great! No isses as all in 20,000 miles.
One caveat: If you want to replace the tire on the 19”, there are very limited choices. I had thought of trying a wider tire on front but there are.none for this wheel.
Not the worst but it does limit that choice.
Old 12-01-2019, 08:41 AM
GTK's Avatar
GTK
GTK is offline
About the only negative in switching is that you will feel more road surface imperfections with the 19" vs the 16".
Old 12-03-2019, 06:01 AM
Hard Ride's Avatar
Hard Ride
Hard Ride is offline
Default 19" front wheel
I have Freewheeler rears and a Street glide front...
Old 12-04-2019, 12:00 PM
Wmitz's Avatar
Wmitz
Wmitz is offline
With all the new electronics, you might want to check with somebody, maybe hd directly, about big differences in tire circumference. There might be an adjustment for such issues the digital tech can make. The braking system on the 20’s works really good, and is well balanced when braking really hard. Just a thought.
coma
General Topics/Tech Tips
12-07-2015 08:17 AM
aclaimsman
Wheels/Tires
03-02-2015 07:43 PM
OOgoon
Wheels/Tires
06-20-2014 12:13 PM
dlrshort
Wheels/Tires
10-02-2010 07:26 PM
texaspirate
09-14-2007 04:40 PM
Quick Reply: Change Out Ultra Triglide Front Wheel for Freewheeler 19 inch size?
