Heat on Right Leg
Cool Thighs
I would recommend floor board extensions and wrapping the down tubes and headpipe. Really if you have not removed the catalytic converter you should do that first.
We are a sponsor here and make a product called a Crotch Cooler..here is a link of what a lot of folks here have to say about our product,it would definitely help her.Thank You https://www.hdforums.com/forum/touri...that-work.html
As mentioned read posts on heat mods. My sig. lists what i have done to wifes trike. In addition i added a reach seat also as my wife is short. You can also try the zippers hiflo air cleaner, it keeps the same position as stock but backing plate is way more open giving more air flow
Our product is not just a cover up if she has short legs the hot components will always be a problem..We have 3 fuel injected Harleys all with fuel management from Fuel motto,while it helps the bikes run cooler and better the heat is still a problem..it is an air cooled motor..
I also like the bling, you got those in a studded version yet!
Jim
Highway pegs on the engine guard (if it's a TG Ultra) are a great relief to pull the legs up and away from the engine.
