Wood TW-555 Triglide Dynos
Well one down and one to go. This past Saturday my dads 09 Triglide was put on the Dyno and the results are as I had expected. I was fortunate that I was able to participate in the tuning process, most shops run you off to a lounge. Only thing I dropped the ball on was I didn't mention I wanted the chart in SAE, its in STD. For those wondering the difference between the two here is a quick explanation.
SAE:
"SAE (Society of Automotive Engineers), USA. Power is corrected to reference conditions of 29.23 InHg (99 kPa) of dry air and 77 F (25°C). This SAE standard requires a correction for friction torque.
STD:
STD is Another power correction standard determined by the SAE. Power is corrected to reference conditions of 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5°C). Because the reference conditions include higher pressure and cooler air than the SAE standard, these corrected power numbers will always be about 4 % higher than the SAE power numbers. Friction torque is handled in the same way as in the SAE standard."
Even though the chart is in STD it still is a good apples to apples comparison between last year with the SE255 vs the Woods TW-555, these runs are 5th gear runs. On the chart the green line is a final run from last August when the SE255 cams were installed. The red is the very first pull before any tuning with the TW-555 cams. The blue is the final run. I know some power and torque was left on the table, but it was a mutual decision between me and the tuner not to go after the timing tables and try messing with other AFR's. The goal was a straight forward tune to calibrate the VE tables and touch upon anything else which looked like it needed massaging along with getting the AFR set at a reasonable value to promote cool running, decent fuel mileage, smooth running and most of all no pinging even with a tank of marginal fuel.
When my dad and I went into this latest cam change the goal was to choose a cam with a later intake close to lower the CCP so it is not as particular on fuel quality and still maintain decent low end torque.
One item which shocked the tuner was how much faster the engine would spool up and reach the rev limiter which was set at 6200 rpm. This was a combination of the gearing change from 32 tooth transmission sprocket to a 30 tooth and the cams. If we remember it my dad is going to ask the tuner to print out the time sheet which shows how quick the run takes, the difference us almost 3 seconds. Note the HP was still going at the end of the run. We could have bumped the rev limiter to see where this cam would start dropping off on HP but seeing there was no reason to beat on it we choose to leave it at 6200.
Once the tune was completed I took the trike for a ride. It rides nice all around from just stooging along at 30 mph to moving along at 80 mph, up hills is a non issue. I did twist the wick a touch and found it would jump to 5,000 rpm quick after each gear change and up to 5th gear 90 mph came quick. Now all my dad needs to do is get some miles on.
Next Saturday we're taking mine to be tuned. It will be interesting to see what if any difference we will see since mine has the Jackpot head pipe and different air cleaner and mufflers.
SAE:
STD:
Mike,
How much torque did you lose under 4K over the 255's? I wanted to PM you with this, but after speaking with my source in the know yesterday I has second thoughts about the 555's. My source says he's seen a 15Ft#-17Ft# loss in torque under 4K on the dyno and is sorry he jumped on the 555 bandwagon so soon.
I'd like to hear more from you and M1 far as seat of the pants feel. I do not think I've gone over 4K on my engine yet and probably never will in the real world unless I have to, so that is not an issue. Just looking for some genuine feedback and looking to spend no more money that needed if you understand where I'm coming from.
Thanks,
Buddy.....
Thanks,
Buddy.....
Mike,
Thanks,
Buddy.....
Thanks,
Buddy.....
I've ridden both trikes and have to say they are night and day different than last year, very much improved. But then we also changed the transmission sprocket from the 32 tooth to the 30 tooth they started using with the 2011 MY. When we get back home my dad will scan my sheet along with a sheet that shows time to spool up his vs mine and his with SE255 vs TW-555. I can say a stock 2010 Triglide made 65 hp and 72 ft/lb torque, the guy who tuned ours tuned a stock one last year and showed my dad the sheet.
