Wiring Trailer Question
I know that this probably seems simple to some of you, but wiring is definitely not my strong point. My question involves 4 and 5 wire connections. I know that non Trike Harleys have a 5 wire and my new trailer has 4 wire and I bought the adapter. But I got to thinking (always dangerous), since the trike uses the same light for both brake and turn, do I really need to use the 4 wire adapter? Or does the rear of the trike use a 4 wire system like a car? Any help will be appreciated.
I used what is called a Hoppe for 5 > 4 wirng was easy.Hopkins said it makes a safety in case of backfeeding and will protect TG's wiring.Just remember the plug is hard to find and the one I thought was correct on my Tg caused me hours od no turns or no brakes.The TG plug is tucked below the one I thought it was to go in.Be sure.
if I recall the plugs are located below the passenger seat.You will uncover one quickly but for me when I plugged into it as I did on my 2wheel Ultra I had issues.Getting frustrated I did this and that and got into more trouble. When I pulled the plug here comes another plug that was deep in the nest.I plugged hitch wiring into that plug and no more trouble.
You will find it and it is a common error,hope this saves time and trouble because of the turn lights on the fenders it is wired diff. than 2 wheelers.
T K
T K
http://www.rivcoproducts.com/instruc...%20Booklet.pdf
T K
T K
