Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri Glide Reverse
Old 06-22-2015, 09:35 PM
Diamond lil 2010's Avatar
Diamond lil 2010
Diamond lil 2010 is offline
Mine does it all the time when backing up an incline
  #32
Old 06-22-2015, 10:06 PM
screwball's Avatar
screwball
screwball is offline
Just a couple of things to try. Release the reverse button while coasting, before you put the break on. This will give the disengage spring time to release the reverse gear from the flywheel. Also, try driving up an incline, and coasting down the incline. As mentioned several times in the 3 pages of posts from old timers who rode before reverse, think ahead before parking.
Good Luck
  #33
Old 06-23-2015, 03:33 AM
msocko3's Avatar
msocko3
msocko3 is offline
Good Luck
I agree, I always selectively parked, even still do with the Wing which has reverse. I only used reverse on the 2010 Triglide I had, when I had no choice.
  #34
Old 06-23-2015, 07:58 AM
Hewatson's Avatar
Hewatson
Hewatson is offline
My brother had the champion reverse installed. I think he will tell you it was one of the better mods he has done.
  #35
Old 06-23-2015, 03:36 PM
Casper's Avatar
Casper
Casper is offline
I also try and be careful where I park, but if ( or when) my reverse goes south I'll replace it with a Champion reverse kit, or not have one at all.
  #36
Old 07-16-2015, 05:58 PM
cybercytes's Avatar
cybercytes
cybercytes is offline
5th Gear
I have a 2011 Tri Glide.
I seldom use the reverse.
Even HD dealers told me that it is fragile.
Being a short legged person, it is an effort to walk it backwards, but I've gotten good at it.
Bottom-line, it's in the shop now getting its 3rd replacement motor.
The last two took me almost a month each to get the bike back.
Dealer said HD required the motor be sent to them for inspection BEFORE they would send the replacement.
Four(4) reverse motors in four(4) years on a new bike....!!!!
Is anyone interested in starting a class action?
UPDATE: HD nolonger requires the dealer to send the motor back for inspection before shipping the replacement
  #37
Old 07-16-2015, 10:45 PM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,084 Likes on 3,486 Posts
Is anyone interested in starting a class action to get HD to install mechanical reverses?
I dis-like the Harley reverse also, but to make it last longer try & remember all it is is a starter motor. How long would you crank on your starter & still expect it to run???
I have seen people backing across the parking lot. Not a bright idea.
Just say'n......
As far as trying to force Harley to change to a mechanical reverse,,,, They will tell you this is how we build them, & they work for what we want in a reverse assist device to just help move the heavy Trike to the point you can move it without using the reverse.
Also, if you want something different they will be happy to install it for you for a price.
I have had one motor for my '12 working for over 3.5 years. I use every time I take the Trike out at least 2-3 times/ 3 to 5 times a week. No problems other than it won't back up much of a grade. But saying that, it might quit tomorrow. LOL !!
But go ahead, I just don't think you are going to win.
JMHO.....
  #38
Old 07-18-2015, 06:11 PM
wijr1949's Avatar
wijr1949
wijr1949 is offline
I am very careful about how and when I use reverse.
I did have the lockup happen one time and it was my fault.
I put the bike in gear before it was completely stopped rolling backward.
Tripped the breaker once trying to unload from a trailer, before I put the lift kit on.
Other than that, I have no problem with reverse and I use it regularly.
  #39
Old 07-19-2015, 08:39 AM
DSLKSL's Avatar
DSLKSL
DSLKSL is offline
Mines in the dealer right now waiting for a breaker. 1,781 miles on it. The breaker would pop before the Trike would even move on a flat surface. Also had it stay engaged on a flat surface. Worked fine right up until now
  #40
Old 07-19-2015, 10:04 PM
Diamond lil 2010
My reverse went out today.also all my gauges quit working.dealer said it would be 3 weeks before they get to it.what I don't under stand is if it's going to take that long why don't they get you a rental car.this is my only means of transportation.if a car breaks down under warranty a dealer will get you a rental until it's fixed
Quick Reply: Tri Glide Reverse
