Trike & Touring download, same?
While shopping around for a new trike my local dealer said no downloads are available for performances upgrades on a trike.
Talked to 2 other dealers today. Both of them said trikes use the same download as the touring bikes with the exception of bank sensor.
Was told if the upgrade says ok for touring models, and doesn't specify except trikes, good to go.
In my case it would be 255 cams, air cleaner, possibly mufflers, and a Stage 2 touring download.
Thoughts?
Thinking this route I could add a piggy back tuner if needed, and remove it if necessary for a breakdown on the road. Bypassing any warranty issues.
Thanks
Thoughts?
Thanks
Thoughts?
Thanks
Thoughts?
Thanks
The following is just my opinion, there will be others.
Any "flash" you get from HD will be inadequate at best. Purchasing a "flash" tuner that has the ability to tune your VE tables is the way to go. There are many brands that do a good job and others that do a great job... they all cost about the same. These flash tuners have the ability to reload your stock calibration "if" there is a warranty issue. I've taken in several bikes for warranty issues without removing my tune and had no issues. Depends on if you have a Customer Friendly dealer.
A piggy back tuner is another way to tune, yes... but their performance compared to a flash tuner doesn't' make the grade and is a waste of time, money and fuel mileage. If you have to remove a piggy back tuner and take it to a dealer there will be a historic code for your 02 sensors shutting down. The dealer will know this. Piggyback tuners don't use your 02 sensors therefor deny the ECM the ability to "learn" and adjust as you ride.
Again, just my educated opinion. There will be others...
Before drinking the Kool-aid do a lot of research and make a good decision. Don't let $$ drive your motivation.
There is no difference in the Tri Glide and Touring "flash".
Your right on, due to the extra 400 or more lbs of the trike vs touring bike the trike may not be able to handle as much timing depending on the build or no build.
Don't know about HD's flash, but with the mods you are talking about, I don't thik the HD thing will be near enough. A Power Commander V with a custom download from Fuel Moto is only 299.00, and this would give you what you need. Is is also removable in case of breakdown and warranty issues.
I am assuming (you know what that does) that the TriGlide and the Touring are different, as I got different, specific custom loads from Fuel Moto for the Tri and the Limited.
Bill
Bill
heavymetalthunder
03-27-2014 01:14 PM
