Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Mechanical reverse
Old 12-21-2018, 09:00 PM
470004's Avatar
470004
470004 is offline
Received 15,150 Likes on 6,263 Posts
I went with MotorTrike since it has an engine cut off if you have the bike in a forward gear and reverse at the same time. I also kept the electrical reverse. The electrical reverse is easy to use, where as the mechanical reverse requires more steps. Both has it places and situation.
Old 12-22-2018, 01:23 AM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,082 Likes on 3,484 Posts
Baker also has a reverse that goes in the transmission. Reverse is operated with the stock shift lever and is locked out by a toggle switch to unlock the reverse. No hand shift lever at all. At least that is what I have read on the write-ups. The shift pattern is R, 1st, 2nd, 3rd, 4th, 5th , 6th.
https://bakerdrivetrain.com/products...nt=16099193411
It is a bit spendy, ($2195.00) and self install, but it is Baker, and well built as always, and all internal to the transmission except for the switch .
Old 12-22-2018, 01:40 PM
john lee's Avatar
john lee
john lee is offline
Originally Posted by Tampakingpin
I have had no problems with electric reverse. Uphill it is sluggish but no other issue.
have you got a picture and how does it work.for me i have to buy a later trans to fit the mechanical one.thank you
Steevo Jolly
07-24-2018 05:58 PM
Moondogger
10-10-2012 09:38 AM
jada3058
06-04-2011 07:06 PM
Ironhorsepilot
04-18-2011 07:27 PM
skulznflames
Exhaust System Topics
06-04-2008 10:03 AM
Quick Reply: Mechanical reverse
