D&K Comfort lift
D&K Comfort lift
Hello All I will be receiving my new Comfort lift kit Mon or Tue I have read a few notes that people like these I hear ride is better . however the ride is ok with me now I read that it helps the steering That is what I am after not that it is to hard but definitely would like a little easier in town . and are they hard to install . looking forward to the input . Thanks guys this site is awesome and it has given me lots of great tips thanks
2011 cool blue Vivid Black . stage one air cleaner, road Zeplin seat, comfort lift kit , rear bumper, lighted luggage rack, long ride 10" sheild, clear paint protectors, many others,
Nope, Put the trike up on auto ramps, the jack the trike till it relieves most of the pressure on the shocks, undo three bolts, take off the old mount and replace with the new, put the three bolts back in, and tighten them up. Takes an hour and a half at the outside with a couple of beers in the middle.
So, no need to remove the wheels? Cool.
I needed to lift my bike when I did the headers. Remembered I had a set of auto ramps stashed in a corner. The bike went right up on 'em no problem and made it a heck of a lot easier to work on. I figure if I need to raise the front at the same time I'll just jack it up. With both rear wheels on the ramps it should be pretty stable.
Bill
Bill
Received 3,962 Likes
It's a straightforward install.
The steering is quicker (easier) and you might enjoy the nicer ride too.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
Most important installation instruction is "Follow the instructions that Kevin sends with the kit". Especially the one that tells you to use a scissor jack under the pully housing to support the axle once you remove the shocks. Don't cheat. Do one side at a time.
