Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
2011 rear belt change
Old 10-29-2013, 07:56 PM
Luzierg's Avatar
Luzierg
Luzierg is offline
Default 2011 rear belt change
Hi everyone,
I just returned from Octoberfest and turned over 59K miles on our 2011 TG. For a winter project I am going to upgrade the alternator to the new high output that Harley has just come out in the new parts book. While I had the front primary opened up I was also thinking about a new rear belt. My belt isn't that bad but I have the time this winter. I like to do all my own wrench work ( I really don't trust anyone else ). Does anyone know of a good instructional manual with photos? I have read thru the service manual several times and it doesn't do a very good job of explaining procedures. Any info or opinions would be much appreciated.
Thanks Gary
Old 10-30-2013, 06:20 AM
msocko3's Avatar
msocko3
msocko3 is offline
If the belt is still in good shape I'd just keep on running it. The stator price seems kind of steep for only 4 more amps, 50 amp stock vs 54 amp for the high output.
Old 10-30-2013, 08:06 AM
icebite1's Avatar
icebite1
icebite1 is offline
Cant help with a better manual but it would be a good time to go thru your clutch pac also. Bet you already thought of that.
Old 10-30-2013, 08:49 AM
RAP's Avatar
RAP
RAP is offline
I'd have to agree with this. Unless your belt shows some obvious signs of failure down the the road, I would leave it alone. You have already changed out your lighting to LED so that right there puts less draw on your stock stator.
Ecoboost
06-11-2013 08:24 AM
mazeppa
05-29-2013 09:14 AM
bigMB
01-18-2013 06:00 AM
davessworks
06-03-2011 06:18 PM
myxcape
01-22-2011 08:19 AM
Quick Reply: 2011 rear belt change
