Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Harley Chrome Tie down brackets
Old 06-04-2014, 08:13 PM
scuba1954's Avatar
scuba1954
scuba1954 is offline
Default Harley Chrome Tie down brackets
Harley has Chrome Tie down brackets 93500011 that are listed to fit the 2014 Ultra glide limited. I have looked at the pdf install for this and it shows that it fits behind the turn signal bracket. Harley shows it will not fit the trike? I have looked at the part number for the turn signal bracket and the ultra limited is the same as the trike. Has anyone tried to see if the tie down bracket will work? It would just make it nice to have a quick place to hook my tie downs instead of using my nylon loops around the engine guard.
Old 06-05-2014, 01:20 PM
8Crow's Avatar
8Crow
8Crow is offline
Won't fit the TG because of the bracket for the steering damper on the left side. Didn't find this out until after I had the tie down bracket installed on the right side and then started on the other side...
A smart man learns from his mistakes but a wise man learns from other peoples mistakes....
Old 06-05-2014, 02:40 PM
Redcrow's Avatar
Redcrow
Redcrow is offline
Yep!!!!! Was going to take them off the SG then realized the damper bracket would be in the way! Maybe someone will reengineer the tie downs to fit?
ApacheAv8tor
10-06-2018 07:08 AM
olvr_vrmr
02-26-2018 06:41 AM
VINNIE JAMES
09-15-2013 06:34 AM
John_HD
Exhaust System Topics
03-22-2013 05:59 PM
jlb0038
06-29-2009 08:08 PM
Quick Reply: Harley Chrome Tie down brackets
