1.18.1 is loaded on Roxy. Install went well and took about 5 minutes. I see no VISIBLE changes other than they added 2 other model icons and STILL DID NOT ADD A TRIKE ICON. I'll ride today and report any found issues. So far so good!!
Yesterday before the new software, I noticed that every time I stopped and started the trike, if playing MP3's one the flash card, I had to go through the menu to get back there. No after the upgrade software it stays where stopped.
downloaded the new update to desktop, moved it to a USB 64G flash drive and the radio will not find it, not sure what I am doing wrong, deleted flash drive and tried again and no luck, missing something
Make sure you unzip or extract the file before you put it on the flash drive.
I had the same problem getting it to read my thumb drive, had to put it on an older memory card and the download worked. However, I've lost the volume control now.
Anyone know how to fix this or revert back to the previous software version.
