Twin cam cylinder head ID?
04-20-2022, 01:56 PM
04-20-2022, 07:01 PM
Do an internet search for - Harley - part# #17193-06A
04-20-2022, 07:28 PM
2007 rear cylinder head from 96" TC.
04-20-2022, 10:00 PM
Is it a 96" head? It has electric compression releases. Assuming unmodified, wouldn't they be 103 heads?
04-21-2022, 07:04 AM
Where do you see the date code?
04-21-2022, 07:52 AM
All HD part numbers end in - and 2 numbers. The last 2 numbers represent the 1st Year that part was introduced. So part # 17096-06A tells ya it's for the 1st year of 96" Twin Cam.
04-21-2022, 08:33 AM
Quote:
Originally Posted by
TexasScooterTrash
There weren't any 96 ci TCs in 06.
04-22-2022, 04:39 AM
I believe it to be a 2016 head. See the 16 with the circle around it.
04-22-2022, 07:59 AM
Max_Headflow You are correct, NO 2006 96" Dyna's. HOWEVER they started producing them in 2006 for assembly on the 2007 96" engines.
04-22-2022, 08:57 AM
TexasScooterTrash
The same casting was used on the 2006 88 ci motors as well. I've had both.. So they started in 06 for 06 models.
schmittles
Touring Parts
04-04-2021 04:08 PM
Snyder191
05-09-2020 09:32 AM
32roadking
04-26-2009 05:34 PM
Punky Brewster
02-27-2007 10:45 AM
HDF Tech
Engine Mechanical Topics
10-18-2005 12:18 AM
