New to Harley and need help already
Old 09-29-2014, 09:20 PM
special_eddie's Avatar
special_eddie
special_eddie is offline
Stage I
Red face New to Harley and need help already
Hey fellow riders,
First I'd like to introduce myself My name is Ed and I own a street glide special; hence the special_eddie. It is my first Harley.
I am looking for some help....I replaced my stock pipes with Vance & Hines power duals and now I am getting popping through the intake and a pinging noise. What did I do wrong? My bike is throwing codes for lean cylinders and rich cylinders as well (131,132,151 and 152).
Other pertinent info, my intake is Vance & Hines and I have FP3 map too.
I have contacted Vance and Hines and they are telling that it is a bad o2 sensor. I didn't do anything with the o2 sensor accept take them out and put them in. Do I replace both o2 sensors? I have read that mufflers can cause this problem as well.
Old 09-29-2014, 09:25 PM
Dake's Avatar
Dake
Dake is offline
Received 1,038 Likes on 1,030 Posts
Welcome to the forum from rainy Georgia! Don't know anything about fuel injected bikes
Old 09-29-2014, 09:28 PM
heritageblue2013's Avatar
heritageblue2013
heritageblue2013 is offline
Try disconnecting the o2 sensors, then disconnect the battery over night. Then try reconnecting everything and go ride see what happens. If it throws codes again, then maybe I would try replacing the o2 sensors.
Oh.......welcome to the great forum of all time!
Old 09-29-2014, 09:30 PM
touchdown's Avatar
touchdown
touchdown is offline
Received 1,672 Likes on 955 Posts
sounds to me its not programed right. When you say power duels do you mean headers, if so hope you changed the mufflers too.
, also the air cleaner. Your local HD shop should help you out.
Old 09-30-2014, 12:47 AM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,083 Likes on 3,485 Posts
Welcome to the HD Forums from Idaho special eddie ! You might get a much better response by going to the correct forum tho. Maybe the tuning forum also. But onr thing to check right Quick is did you get the wiring reversed on the O2's front & rear ?
Old 09-30-2014, 05:43 AM
russ33541's Avatar
russ33541
russ33541 is offline
Welcome to the forum from the Tampa area
Old 09-30-2014, 06:18 AM
the wild hog's Avatar
the wild hog
the wild hog is offline
Received 2,867 Likes on 2,824 Posts
Welcome
Old 09-30-2014, 07:28 AM
lemonade_07flstc's Avatar
lemonade_07flstc
lemonade_07flstc is offline
Welcome to the Forums from Central IL
Old 09-30-2014, 07:33 AM
1BRAVO9's Avatar
1BRAVO9
1BRAVO9 is offline
Welcome to the forums and good luck with your issue.
Old 09-30-2014, 08:47 AM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,941 Likes on 1,925 Posts
__________________
Quick Reply: New to Harley and need help already
