97 Road King idle/throttle problem
I'm working on a 1997 Road King, and I'm trying to figure out why it idles up by aprox. 300 (or more) RPM's at intermittent intervals, and when it does, the throttle has a serious hesitation in it. Then it will idle back down to normal, and it's fine. No hesitation. Also, it doesn't start doing this until it's been running for about 15 minutes. I'm thinking it could be a heat issue with one of the components. It will do it for about 10 minutes or so, then idle down and run fine. It has a Power Commander III on it, but it does it whether it's hooked up or not. Would the crankshaft position sensor have anything to do with this? If anyone can help me, I'd certainly appreciate it. Thanks
Congrats and Welcome to the forum.
To learn how to get around in here Go to the forum main page and look it over, there are a lot of sections and areas to address your questions. E.G. Areas for different bikes, Areas for Tech?’s;. Frame;, Motors;, Tires;, Oils;, Lights:, etc.etc Just look it over and U will learn the ropes in here.
Most of the common questions like, (What’s the) best mufflers, best seat. Best Cams, best tires, best oils have been asked hundreds of times for years. Doing a search in this forum and even Google will get most of your questions answered.
From Indy.
From Indy.
1 Post
Congrats and welcome from central Washington. Great site and even better people. Use the search function and snoop around a bit before asking questions . Just a little brotherly advice. Glad you're here . Geezer
