Tramsmission Fluid and filling?
Hi,
I'm new to harley's worked on dirt bikes and four wheelers. I'm wonddering where the fill to fill the transmission is or where i should look on my mom's 1200 Sportster? (it is truthfully my mom's) Also what should I use for tranny fluid in it? Thanks for all who read this let me know I want to ride it.
Thanks,
Buddy
Thanks,
Buddy
I pulled a plug under what i think is the transmission (where the shifter is) toward to rear of it. Then I pulled the hose off the plug and drained the oil tank. What is the difference between the two?
You can fill the primary thru either the inspection cover hole or derby cover hole.
HD makes a lube for it. Other people use other lubes. My Sporty has been running 30wt non-detergent motor oil in the primary for 3 decades and is still going strong.
I know this is probably a dumb question but is that one of the covers on the transmission or is it somewhere else? (These are so much more complicated)
