Swapping 07 Deluxe wheels out for 07 Street Glide wheels
Old 12-11-2017, 09:35 PM
Shane T's Avatar
Shane T
Shane T is offline
Default Swapping 07 Deluxe wheels out for 07 Street Glide wheels
The Street wheels are laced chrome profile and appear to be identical to my Deluxe wheels(except mine are stock not profile). They both have 25 mm axles but according to the parts finder they have different bearings. Deluxe are 9276 and Street are 9247. I am assuming this means the OD is the difference so I should use the Street bearings and sleeves. Am I right?
Old 12-13-2017, 06:16 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Wink
Take another look at a parts website! H-D did some odd things IMHO, until they standardised on 25mm bearings across the range. If your DL is a genuine 2007 model, the rear axle and bearings are 3/4", however if it is a late 2007 build, but early 2008 model, it has the metric size. The '07 SG however has 1" ID bearings and axles in both wheels, unless it also is a late '07/early '08.
Harley introduced sealed ball races around 2000, but of different sizes across the range, for some perverse reason. All early sealed-bearing wheels however use the same OD bearings - 3/4", 1" and 25mm, so they can be interchanged, with suitable central spacers. I have a 2004 Deuce rear wheel and 2010 SG front wheel in my Glide, but with 1" bearings in both.
Old 12-13-2017, 07:46 AM
Shane T's Avatar
Shane T
Shane T is offline
Thanks for the info. So I just need to measure my axle and use the suitable bearing and sleeve.
Old 12-13-2017, 07:59 AM
grbrown's Avatar
grbrown
grbrown is offline
Yes, check what you actually have! What I did was buy the H-D bearing kits, which come with bearings plus the correct spacer. For details check the H-D website Shop tab.
Old 12-13-2017, 03:04 PM
Shane T's Avatar
Shane T
Shane T is offline
The build date on my Deluxe is 11/06 so I'm assuming it is considered an early model with the 3/4" axle but I will confirm it. HD wants $90 for a bearing kit, I'll look somewhere else.
Old 12-17-2017, 04:34 PM
grbrown's Avatar
grbrown
grbrown is offline
Sounds as if your bike is indeed an '07. Check the price of the correct bearing spacer! I live in the UK, but reckoned it was simpler and a decent price to get the kit.
Kasper_516
05-27-2022 03:34 PM
Shane T
10-03-2016 08:03 PM
Rhino200099
02-15-2013 05:40 PM
usarmyttt
05-08-2008 11:08 AM
nervousnorm
04-21-2007 01:00 PM
Quick Reply: Swapping 07 Deluxe wheels out for 07 Street Glide wheels
