Tires
Old 11-04-2018, 06:25 AM
Loose Nut's Avatar
Loose Nut
Loose Nut is offline
Default Tires
If I wanted to install a wider tire on my stock 17 SGS do I have to change the rim to accommodate the wider tire?
I really like the wider tire as it looks bad a - - .with keeping the stock look.
Old 11-04-2018, 09:10 AM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
I thing you can keep the rim looks great with a wider tire on it.
Old 11-04-2018, 12:45 PM
Loose Nut's Avatar
Loose Nut
Thank you for the reply. Going to have that done over the winter months.
Old 11-05-2018, 06:31 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Exclamation
That's a very open question! You really should investigate a bit further before buying anything. The largest you can get away with is probably a 200mm, without making mods. As your bike is a Touring model I recommend you visit the Touring section, where you will find umpteen posts on doing this and plenty of members who have done it.
Maniscoco
01-17-2019 10:32 AM
ttucker4695
12-20-2018 08:30 PM
Londonbike
2014-2023 Touring Models
45
09-14-2018 09:26 PM
67Shuv
The Dark Side
11
04-03-2018 06:45 AM
SC-Longhair
04-23-2010 07:44 AM
Quick Reply: Tires
