ABS vs non ABS
ABS vs non ABS
I have a 2010 with no ABS and I'm considering buying used 2016 ABS wheels from another forum member. I understand why ABS bikes need ABS bearings, but is there any reason why the ABS bearings won't work on a non-ABS bike? Will I need to change bearings anyway for axle size or spacing difference from 2010 - 2016? Thanks much!
It will work perfectly well, although I believe you may need a different spacer on the ABS side of each wheel. An alternative is to swap the bearings, although that may also require a new spacer (between them). This subject has popped up before, so there are other threads about it, also over in the Touring section.
I ordered a 3mm smaller spacer for the ABS bearing side on ebay and left the new ABS bearing in worked great.
https://www.ebay.com/itm/25mm-ID-Har...cAAOSwo0JWHFuN
