Will 17" rims fit 2002 EGC
Same can be said about a locomotive…
You'll need to change out that ABS bearing to a STD bearing ... ((2) New brgs)
Get a 2008-later 25mm axle and wheel spacers and it's plug n play ... (other than rotors or calipers)
OR
Use 1" OE# 9247 bearings (as 88 mentioned above) and custom wheel spacers. The wider bearings will protrude slightly.
OR
Use 1" aftermarket bearings (same width as the 25mm bearings) and use semi custom wheel spacers
You'll also need 08-later Brembo Calipers for the OE Impeller / Enforcer 11.8" rotors (the 2002 use 11.5")
OR
Aftermarket Impeller / Enforcer 11.5" rotors to work with your 2002 Calipers
OR
OR
OR
The rim is part of the wheel; the tire is a separate part that goes on the rim. A wheel is a hub, spokes, and a rim. The assembly is a "wheel and tire."
Leimy (05-13-2024)
