my front master cylinder seems wet
08-26-2009, 07:31 PM
like the gasket is leaking brake seems a little soft anybody else had this problem its a 08 softail custom
08-26-2009, 08:12 PM
Don't know about the problem, but wash that master cylinder down thoroughly before the fluid eats your paint.
08-29-2009, 07:25 PM
Had to replace mine for the same reason.
The fluid did eat some of the paint around the top edges of the master cyl.
10-08-2009, 10:44 AM
I have the same problem
I have the same problem. Was the repair covered by the warrenty? and will they cover the paint that is blistering on my master cylinder?
10-08-2009, 10:48 AM
If the cover is on too tight it will leak a bit. Try loosening the screws a bit. Or now maybe get a new seal and put on but do not tighten too tight. How tight is too tight? If it leaks, it is too tight.
rsscoggins
Wheels/Tires
08-19-2012 10:53 AM
rsscoggins
Wheels/Tires
08-18-2012 02:07 PM
outlaw0013
09-27-2010 09:31 PM
italfatboy
08-19-2010 07:21 AM
mtpoland
09-23-2007 09:20 PM
