Are my tires too old?
Just bought a 2003 100th anniversary FLHTCUI, with only 2090 miles. I am excited that I got a bike with such low miles, but am concerned about the age of tires. Is there an age when they should be replaced even though they have low miles? The bike is in storage so I haven't checked the manufacture date on tire, but obviously they are at least 8 years old.
Lots of opinions on this one I'll bet. Heat and sun light both can degrade tires. Bikes stored in sheds (especially in the south with high temps)for extended periods of time can see tires degrade fast. The obvious place to see heat related damage in on the side walls. Look for cracks. they won't necessarily be big.You should have none. Now, I have rode on tires with what looked like small spider web cracks on the side walls. They had little tread wear but the bike was stored in a shed for a couple years. Would I chance it again? Nope. I'm a lot older now and don't feel quite as bullet proof as I used to.
Depends
Five major automakers, BMW, Chrysler, Ford, Toyota and Volkswagen/Audi, already warn against using tires beyond the six-year point, and three tire producers -- Bridgestone-Firestone, Continental and Michelin -- recommend a 10-year age limit.
The Rubber Manufacturers Association, which represents tire makers, disagrees with age limits. They contend that factors such as storage, maintenance and weather are more important.
Any doubt or question
That is what I would do. I have just fitted new tyres on my 03 Dyna, bought new, but with low miles. It spends all its non-riding time in the dark, but I could see the tyres were showing their age. Also they are Dunlops and they ain't anything to write home about, so it has Avon Venoms on it now!
Update
I talked to the service department where I bought the bike and they said the bike was safery inspected and the tires are fine. Dunlop says they are good for 10 years. So I am gonna pick up the bike and ride it to my local dealer. He also thought they should be good, but told me to stop by and he would check them for me. So before I let my bride ride, I'll make sure they're good or replace it. Tire failure not an option.
Anybody use Doran 360M tire monitoring?
Several dealers and independent mechanics that I trust are telling me that the age of the tire should not be a problem as long as it was stored indoors out of the UV light. So I think I am going to keep the original tires and install visible tire pressure monitors like I had my last bike. Advance Auto sells Victor TPmonitors but only for 32psi and 36psi. http://www.tireqp.com/ sells American made chrome valve stem covers that come every 2 psi. The manual FLHT says F36 R38/40 but my dealer recommends 40 psi both so I am going to get 38 both wheels.
Any time I get on my bike a quick glance tells me if my PSI are WNL. I do like the idea of a wireless monitor that has transmitters either in the valve cover, or in the tire. What do you guys think? link below.
http://www.doranmfg.com/motorcycle-t...ng-systems.htm
I think you should re-examine your priorities and put the money towards new tires. Your old ones may not even have visible signs of deterioration, but are more than 8 years old, and have age-hardened, losing some of their grip. You will notice an immediate improvement in the ride & handling. What's more important: safe tires or saving time checking the pressure?
