leaking brake bleeder valve
Old 03-13-2012, 08:58 PM
darkwing96's Avatar
darkwing96
darkwing96 is offline
Default leaking brake bleeder valve
Has anyone had a issue with their bleeder valve leaking? Mine is leaking on my front caliper. I have tried to tighten it, but it is still leaking. Any suggestions?
Old 03-16-2012, 04:58 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Only that there may be dirt on the seat where the nipple should seal. I would remove the caliper, clean it thoroughly, including the hole where the nipple fits. If the tip of the nipple looks rough replace it. Best of luck.
Old 03-17-2012, 02:08 AM
racing geek's Avatar
racing geek
racing geek is offline
6th Gear
BEFORE YOU PULL THE CALIPER APART...
Have you washed the caliper off around the bleeder or just wiped it off? Moisture in the air could make it look wet again if you didn't get it all wiped off.
Another possibility could the residual in the bleeder valve is now coming out from when you last bled the brakes (have you done it recently?). Did you stick the corner of a paper towel or use a Q-tip to remove the brake fluid in the valve before you capped it?
zworld
01-28-2012 11:56 AM
sammer4u
Wheels/Tires
06-30-2011 07:22 AM
RocketRocker
06-27-2011 09:34 PM
Rich G.
Ironhead
11-03-2008 08:48 PM
jimbo bk13
20
01-22-2007 09:58 PM
Quick Reply: leaking brake bleeder valve
