tire expansion?
Old 02-07-2014, 06:45 PM
dsonnenberg's Avatar
dsonnenberg
dsonnenberg is offline
Default tire expansion?
How much clearance do you need from your tire to your fender? Where is the tire goibg to expand the most? I have about 1/4" room between side of my tire and fender
Old 02-10-2014, 10:54 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
As a wheel spins at speed it grows in diameter, doesn't get any wider. I have about the same clearance as you do, on my rear tyre!
Old 02-10-2014, 10:57 AM
grbrown's Avatar
grbrown
grbrown is offline
I assumed you meant side clearance, if you mean between the tread and fender, at the largest diameter of the tyre, you may just have enough clearance, as long as there are nuts or bolt heads in the way!
Reccerick19
Wheels/Tires
05-24-2014 03:52 PM
mobsters1972
03-19-2014 02:22 AM
JohnK-NJ
12-09-2013 05:20 AM
roccitybiker
07-03-2010 06:58 AM
HarleyMom883
09-26-2007 10:42 PM
Quick Reply: tire expansion?
