Biketronic 2014 7.1's and their line leveler
Took advantage of the recent Biketronic speaker sale and ordered a set of their 7.1's with the mounting brackets and their line leveler. I have to see for myself what you guys have been raving about all this time! LOL! I will post an update after install. I may swap the magic box for their line leveler before swapping speakers and pods so I can compare the two with the Hertz HCX 165's. Going to stick with the Cerwin Vega B2.
It's a sickness....
It's a sickness....
It works...
I had the Magic Box with the BT2180 and 7.1's. Sounded horrible. Bill sent me his new line leveler and all I can say is WOW. What a difference. Now my system rocks, sounds great running at 80. I did add foam round rod between the speaker bracket and inner fairing which I think is also adding to the performance.
Next up, lower fairings with BT 6.5's.
Say what
__________________
NO, they DON'T all do that!
Also on amazon.com...
Well I just placed an order for the BT line leveler. I hope I experience similar results! Mine sounds good now but I think it could sound better. We shall see!
That was a little trick I posted a while back, there was a 1/2 inch gap between the speaker brackets and the fairing.
I wanted to isolate the front of the speaker from the air coming from the rear speaker to see if it made a difference
in sound and it did. I used 5/8 foam backer rod from ace to fill the gap.
