Budget minded build started
So today I have modified the aftermarket speaker grills to fit the inner fairing and mounted the tweeters in grills and mounted front speakers. Tried fitting rear speaker in tour pack but no luck. I guess I need a spacer ? Tried test fitting my amp in place ( pn41000d ) ......how the heck do you guys get it in there ? I removed the end covers to see if that helped. May take the zip blade to the tabs. So next question is how close to the gauges does it need to be ?
You need to put those end caps back on that amp my friend. Provided a link to help you fit that amp.
https://www.hdforums.com/forum/audio...pn4-1000d.html
Big Dave (03-23-2017)
