Boom Handlebar Speaker Mount Audio Wiring
I purchased a Harley Boom Audio Handle Bar Kit (p/n 76262-08) and the install is easy except for the wiring and no diagram is provided. Just confusing text! It looks like it needs a Hot, Switched Hot and Ground to connect it, I am replacing a HOG Tunes MA-2 system and this is how that was wired. But, Harley wants you to cut into the main harness; which is just not healthy. The wires to connect are RED, ORANGE and BLACK. Does anyone have any knowledge of this?
Thanks
Thanks
This setup was draining batteries so HD added a relay & different wiring using the harness, relay & a 12V adapter wire. I'll try to find the it as it has been posted here.
Here you go. page 5 shows the relay & 12V adapter with comes with the boom system (or maybe it's in the relay kit).
http://www.harley-davidson.com/en_US...ts/-J05523.pdf
Boom Audio Wiring
Thanks very much for the information and link.
The H-D instructions for the link above are for the Windshield mount version. Here is the Handlebar speaker installation: http://www.harley-davidson.com/en_US...ts/-J05522.pdf
(I found this by accident by just changing the pdf number!) in case someone else needs it.
These are different than what came with the unit.
Really useful site, just wish there were a search on it.
Thanks
Thanks
I have an older version of the windshield mounted system and there is no mention of a relay or needing a relay.
How/why does this setup drain your battery? Unless the ignition or accessory switch is turned on, the orange and white wire should be off. If the orange and white wire is off... shouldnt the speakers be off?
That sounds familiar.
