1995 Electra Glide speakers
Old 02-14-2013, 01:26 PM
finley54's Avatar
finley54
finley54 is offline
6th Gear
Default 1995 Electra Glide speakers
It appears I can only put a 4" speaker in the fairing of my 1995 Electra Glide. I'm having an issue with the fact that all speakers seem to mount on the outside with a grill cover. Even if I knock out the existing grill covers (they appear to be glued in), it doesn't look like there is enough room to put a speaker cover. Do they make a speaker that mounts on the inside and I just leave my stock cloth covers on? Any help installing a system will help. Going to go with a 'media player'. No CD. Any suggestions are appreciated.
thanx,
Putter
Old 02-14-2013, 01:52 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
man you're pretty limited on what you can do there.. Check these out as they'll fit the bill.
http://www.eglidegoodies.com/id72.html
Old 02-15-2013, 08:50 AM
finley54's Avatar
finley54
finley54 is offline
6th Gear
Thanx for the link UltraNutZ. I'll check it out. You're right, I am limited. Seems like '95' was the break for a lot of things. I've had to modify most everything I do including late style seat, quick attach sissy bar and tourpack, but after spending what I did on the engine, I'm not ready to get rid of it. Again, thanx.
Old 02-15-2013, 08:53 AM
UltraNutZ's Avatar
UltraNutZ
i hear ya, not to mention it's a looker.. is that an S&S powerplant?
Old 02-15-2013, 01:31 PM
finley54's Avatar
finley54
finley54 is offline
6th Gear
No, not an S&S. Started as a stock 'police' 80" which is 5 HP higher from the factory to begin with. Bike had a knock when I bought it so I knew it needed to be rebuilt anyway. Oversize pistons, Crane cam, all new valve train, flywheels, rods, etc. balanced. Head work done, and a little squish on the heads for compression. Then put a Mikuni carb and a big sucker aircleaner, and it runs pretty well. Lotta torque for pulling hills. Blows people away how I can pull em on a hill. Thanx for the compliment.
Old 02-16-2013, 08:41 AM
beardogg's Avatar
beardogg
beardogg is offline
3rd Gear
polk audio DB401 in mine sound great and bolt right in
Old 02-16-2013, 08:42 AM
beardogg's Avatar
beardogg
beardogg is offline
3rd Gear
I put polk audio DB401 . They sound great and bolt right in.
Old 02-26-2013, 09:42 AM
finley54's Avatar
finley54
finley54 is offline
6th Gear
Default Polk
Thanx beardog. I notice the Polk wants to mount on the outside, which means I would have to knowk out my grills. Is that what you had to do? Then it doesn't look like there is enough room to put the Polk grill covers on. I guess one of my real concerns is also will I even be able to hear 4" speakers going down the road? . . help . . again.
PstrGolf
03-16-2018 04:27 PM
JKalk
03-03-2016 08:08 AM
finley54
02-14-2013 12:26 AM
Phil George
07-12-2012 09:14 PM
woody0404
EVO
11-27-2011 08:38 PM
Quick Reply: 1995 Electra Glide speakers
