Power Distribution
Power Distribution
What's the best/recommended method of connecting a number of accessories to the battery for power and ground? Does everyone just connect directly to the battery or is there some sort of power distribution block I should use? For instance, on my bike I have and will need the following devices connected to the battery:
battery tender cable
relay isolator for trailer
amp
motolights
This just seems like a lot of ring terminals to attach to the battery post. I'm not even sure the battery tray cover would fit (2011 Ultra) with this many ring terminals connected.
amp
motolights
If you want to keep your power tray clean and neat then put one of these to the left (in front of) of your fuse panel under the left side cover.
For the accessories you're talking about, I would run an 8ga wire from the battery to the distribution block with a 40A inline fuse at the battery.
Then on each of the 4 outputs, you run the recommended wire and fuse size your accessory calls for.
Word to the wise. If you do this and use screws to mount the distribution block to the plastic as I did, MAKE SURE that the top screw will not pierce the wiring harness that is located behind the plastic.
Here's mine for my amps.
amp
motolights
amp
motolights
Do you already have motolights? Or is that a planned purchase?
amp
motolights
amp
motolights
Now why didn't I think of that???? A simple and obvious solution. I like it. Thanks!
