Head unit swap question.....
Because the wiring harness on the '01 sitting in my garage is clearly the stock one it came with, and it is not the same as the stock one in my '08. Which the '08 models and the '12 models are the same. Why is that?
If you want rear speaker outputs, you'll need to connect wires to pins 1,2,24,25 on the 35 pin connector on the back of the new radio.
Found this in another thread:
98-05 use the high setting. (but 98-03 is analog and needs to be flashed)
06-13 use the J1850 setting
Then from this thread:
And one last question: How do I get into the setup menu to change the AVC setting? Or is that something that's directly accessible from the main screen (again, I don't have the unit yet, so I can't play around to find out)?
