Do i need to disconnect battery
Old Nov 9, 2015 | 02:58 PM
SnoRider's Avatar
SnoRider
Default Do i need to disconnect battery
Manual says to disconnect battery. I took nacelle off, disconnected wiring for handlebars removed handlebars. Going to put new ones on with internal wiring. Should I have really disconnected battery? I did pull the main fuse. 2011 flhrc. Thanks guys.
Old Nov 9, 2015 | 03:22 PM
madsonp's Avatar
madsonp
Pulling the main fuse is about the same as disconnecting the battery, it should kill all power to the bike.
Old Nov 9, 2015 | 03:42 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Old Nov 9, 2015 | 03:44 PM
btsom's Avatar
btsom
UNLESS you are working right around the battery. In that case an errant screw driver or wrench handle could still cause sparks.
Old Nov 9, 2015 | 03:52 PM
SBates08's Avatar
SBates08
^^^^^This^^^^^
True but it'll still do that whether the cables are hooked up or not.
2010 Limited with some stuff
Old Nov 9, 2015 | 04:23 PM
btsom's Avatar
btsom
I was concerned for those who might have interpreted the initial claim for the main fuse as TOTAL de-power and then short a ring or watch band to the positive terminal or cable and get severely burned. If you understand the power layout you can keep yourself safe but if you don't have a clue, follow the directions.
Old Nov 9, 2015 | 04:28 PM
JMC22's Avatar
JMC22
You don't have to do it but for the 1-2 minutes it takes you, peace of mind is always nice - it's just like covering your tank & front fenders - one doesn't need an Ohh $hit moment
Old Nov 9, 2015 | 04:40 PM
deadhawg's Avatar
deadhawg
What's the worst that could happen if you don't disconnect the battery?
You might accidently short a wire and melt it. You might short another wire and fry your ECM. You might short a wire and start a fire that burns up your bike, maybe your garage and maybe your house.
All unlikely, worst case scenarios, but why take a chance?
It takes about one minute to disconnect the battery, so trying to save a minute or two doesn't make any sense at all to me. Doing the job right the first time saves a lot of headaches later. Don't ask me how I know.
Old Nov 9, 2015 | 04:59 PM
TcHunter's Avatar
TcHunter
I completely agree with deadhawg.
Old Nov 9, 2015 | 05:00 PM
SBates08's Avatar
SBates08
Originally Posted by deadhawg
What's the worst that could happen if you don't disconnect the battery? You might accidently short a wire and melt it. You might short another wire and fry your ECM. You might short a wire and start a fire that burns up your bike, maybe your garage and maybe your house. All unlikely, worst case scenarios, but why take a chance? It takes about one minute to disconnect the battery, so trying to save a minute or two doesn't make any sense at all to me. Doing the job right the first time saves a lot of headaches later. Don't ask me how I know.
None of what your describing is possible with the Maxi-Fuse pulled.
