Speaker/Fairing support brackret removal question
Old 08-21-2014, 05:56 AM
Peculierboy's Avatar
Peculierboy
Peculierboy is offline
Default Speaker/Fairing support brackret removal question
Can the stock speaker support brackets in the FLH fairing be removed without any issues?
There are two small metal support brackets that run from the fairing/radio mount to the speakers on each side, and I want to mount a Hawgwired amp mounting plate on one side and the bracket is in the way. On their web site, it shows the bracket is removed for the installation of the mount plate, and it appears as if it was done so larger speakers could be installed.
I have a set of Biketronics speakers already, and the bracket is not in the way, but I wanted to see if removing the bracket would cause any vibration issues....
Old 08-21-2014, 07:50 AM
Oilsmoke's Avatar
Oilsmoke
Oilsmoke is offline
The brackets are Needed to support your Fairing . Leave them installed.
Old 08-21-2014, 10:05 AM
Kave Dweller's Avatar
Kave Dweller
Kave Dweller is offline
You will be surprised how much those little things help. Leave em on
Old 08-21-2014, 10:34 AM
Pioneer74's Avatar
Pioneer74
Pioneer74 is offline
You remove the stock bracket to install the Hogtunes 2nd amp bracket. It acts as the brace. If this Hawgwired does the same thing, by acting as the brace too, then you remove the stock piece.
Tailwind
Audio Systems
13
12-18-2015 08:54 AM
SourMash
Audio Systems
12-09-2014 11:20 AM
bluflstc
Audio Systems
01-27-2014 02:02 PM
iclick
04-10-2012 01:07 PM
russl179
09-13-2008 05:03 PM
Quick Reply: Speaker/Fairing support brackret removal question
