lowered bike scraps pipe
Old 10-21-2014, 10:31 AM
Greezey Rider's Avatar
Greezey Rider
Greezey Rider is offline
Received 2,493 Likes on 1,073 Posts
Originally Posted by blueangel73
If rubbing pegs and pipes are a negative conciquence then yes I have always had this issue and so have many, many others on both raised, lowered and stock bikes. I had the problem with a stock Sportster Custom and the Street Bob before I lowered it. I don't see how rubbing parts against the ground is a negative concequence, it is a consequence of riding a motorcycle, but it's not a negative one. It seems to me that even the guys that raise there bikes to get more aggressive turning ability still rub bike parts. Yes, raising, lowering or leaving your bike stock, via shocks or body weight does change the ground clearance and lean angle, but either way the rider has to learn his or her limits/consequences of using the setup, lower your bike you'll lean less to rub, raise your bike you'll lean more to rub. The guys that race supermoto can lean damn near on the fairing of the bike and rub the bike and body parts on the ground without any "negative" consequences. If you don't want to damage/wear and tear your bike parts then don't ride so hard, take it nice and easy and avoid the consequences of riding hard (or pushing your limits). Pretty much it's only a "negative consequence" if your not expecting it to happen or are worried about the effect of what the change or non-change caused. A negative consequence to me would be something unexpected and caused a crash or death, not a little rubbing here and there.
Well.....Alrighty then.
Old 10-21-2014, 12:06 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
hahaha my primary has drug in turns since the bike was new, is what it is with a dyna if you ride hard... so what for the pipe, on mine i cut and did an upsweep to the pipe, made a mount for it, never had any issues wether i am 8" or 14" ride setting.
we have done a bunch of t header grinding repairs though
before
durring
after
Old 10-22-2014, 04:55 AM
Punty's Avatar
Punty
Punty is offline
Awesome work bro.
shiftace
03-10-2013 12:55 PM
Precision223
04-20-2012 11:55 PM
Mikey 1450
12-18-2010 02:37 AM
archergodwin
03-12-2009 08:35 PM
chugchug
01-27-2009 11:47 PM
Quick Reply: lowered bike scraps pipe
