New Exhaust System
clearance problems mounting these up? Did the 2 into 1 make a difference in power, compared to slip ons or true duals. Your Feed back is appreciated.
Thanks!
i will say that their service is good. i had the rust bucket on there, took a few pics, and sent it to D & D, they sent me a new one quick. but, it fell apart in colorado...... service can be awesome, but does it matter if the parts are crap......
only issue i had with the pro pipe, was ground clearance. it is a big megaphone, and i ride hard, so i ground the ring down, and threw sparks all the time. my rear end is also lowered too though. same thing on the big shots. ground clearance. but, i learned a trick. on the saddle bag support arm, where the pipe hangs from. cut that metal block with the rubber insert off, and weld it on top of the arm, instead of below it. gave me 1 1/2 inch more clearance, and was barely noticeable, unless you knew to look for it.....
ground clearance was not an issue on the D & D at all, and had to put the block back under the bar. performance was the goal and claim to fame for the D & D, but i will not buy one again. going back to V & H for my next build. they never let me down. and now they have their pipes in a ceramic coating! hell yeah!
my couple pennies worth for ya,
but, i have since taken the 'rust bucket' and had it refinished. my powder coater is pretty good, adn it looks like an 850 dollar pipe again. and it is on my new (older) bike.
ride safe guys, because soccer moms on cell phones will run you over....
corb
