FUSE question
FUSE question
Hello:
I have a question regarding the fuses. I have 2003 Dyna Super Glide and was adding some running lights. Well, I had to change the blown fuse due to a short, and to my surprise, when I took off the fuse cover, I saw that someone has put a 30A fuse in the lights slot.....I am no electrician, but according to manual, and to what I have read, it should be a 15A fuse.
I bought the bike used, so I am not certain what has been done to it in the past.
Anyway, I have replaced the 30A fuse with 15A fuse. I have checked the lights and all the things, and it all works fine.
Did I do it correctly or should I have put the 30A fuse to the lights slot?
Any input is appreciated!
Thank you.
Thank you.
If the book says 30 then 30 should be used to protect the circuit.
It would seem that the fuse should have been a 15A.
Using a higher rated fuse is not suggested since it could be over rated for the circuit design.
Previous owner probably only had that fuse available and used it.
The job of the fuse is to protect the wiring, NOT the accessory. If HD states that the fuse should be 15 Amp then that is what you should put back.
While you are about it you should check the other fuses and replace any that are not the correct rating with fuses of the correct rating.
Over rated fuses could easily lead to the wiring catching fire.
I am an Electrical Engineer so please heed the advice before you have a disaster to contend with.
You did the right thing taking it out and replace it with a 15 amp fuse (see image attached).
More wiring diagrams to be found in here:
***Dyna Models Wiring Diagram Links Index***
