The belt to chain drive conversion thread
Old 05-05-2015, 08:59 PM
Lama's Avatar
Lama
Lama is offline
Default The belt to chain drive conversion thread
In an effort to create a informational topic about converting your Dyna to rear (final) chain drive lets start a thread with technical information and experiences to help others in their chain conversions.
** Please refrain from comments and opinions regarding the merits of belts vs. chains... PLEASE **
Some people want chain drive and that's what this thread is for.
First off, some web resources for chain drive conversions and parts:
http://www.bulletproofcycles.com/#!p...b-566205c21498
http://www.bungking.com/dyna-parts/
http://www.deadbeatcustoms.com/deadb...4-harley-dyna/
http://www.zippersperformance.com/pr...kits-dyna.html
http://shop.bigalscycles.com/product...hain-drive-kit
http://kruesioriginals.com/products/...ain-conversion
http://www.shop.pbisprockets.com/cat...c?categoryId=2
http://sidewindersprockets.com/produ...rSprocket.html
http://www.dragspecialties.com/produ...umber=12100366
http://vulcanworks.net/Harley-2000-U...ers-p-369.html
http://rkexcelamerica.com/products/brands/rk
http://www.ekchain.jp/index.html
http://www.didchain.com/streetChains.html
http://www.cyclevisions.com/index.ph...el-spacer.html
https://alloyboltz.com/catalog/index...lf0ttq14ccjfq1
http://www.depss.com/kits.php/9/Belt__Chain_Sprocket/
http://stillkickingmoto.bigcartel.co...ocket-lock-tab
http://www.customchrome.com/catalog/...l.asp?page=633
http://www.summitracing.com/parts/ARP-614-2500
Johnny Goodlife (11-28-2016)
Old 05-05-2015, 09:06 PM
monster715's Avatar
monster715
monster715 is offline
Great thread lama, subscribed... Also if guys could include their sprocket sizes and final drive ratio that would be perfect! I just so happen to be in the market for a chain conversion
Edit: my bad lama I didn't realize you weren't done setting it up... Didn't mean to interrupt
Old 05-05-2015, 09:09 PM
Lama's Avatar
Lama
Lama is offline
Old 05-05-2015, 09:16 PM
Lama's Avatar
Lama
Lama is offline
* There will definitely be two major categories of conversions:
1) 2005 and "below" bikes and their particular parts. ( 5 speed transmission sprocket )
2) 2006 and "up" bikes and the respective needs. ( 6 speed cruise drive transmission sprocket )
** There are two ways to go about this:
1) Buy a pre-made kit from one of the listed vendors.
2) Piece together parts from various vendors and go about it yourself.
*** There are a few reasons people will want to change from belt to chain:
1) Increased tensile strength of a drive chain vs. Kevlar belt. (wheelies, big inch motors, etc.)
2) The ability to alter final drive gear ratios easily without having to continually remove the primary drive.
3) The "coolness factor" of a mechanical appearing chain drive.
4) The ability to change the drive chain for wear or age, without the need for removal of the primary drive system (belt).
**** Some issues needed to be dealt with:
1) The tools and parts needed to perform the conversion.
2) Chain contact with various parts of the chassis and or the driveline.
3) Care for the chain drive after installation.
4) Speedometer adjustment after conversion.
Old 05-05-2015, 09:40 PM
Frank Castle's Avatar
Frank Castle
Frank Castle is offline
good thread... subscribed
Old 05-05-2015, 09:58 PM
Suede Blue Man's Avatar
Suede Blue Man
Suede Blue Man is offline
Not sure if I'd do this but want to make sure I get my post in on the first page of Lama's thread.
You never know, it may end up like his Club/Thug and that thread is like the lost 11th commandment that didn't make it on Moses's tablets
El Subscrido!
Old 05-05-2015, 10:35 PM
Ironhead.Chris's Avatar
Ironhead.Chris
Ironhead.Chris is offline
Awesome thread Lama! Thanks for putting it together.
-Chris
Old 05-05-2015, 10:38 PM
Lama's Avatar
Lama
Lama is offline
Tool vendors to allow removal and installation of the primary, clutch mainshaft nut and pulley/sprocket nut:
http://www.georges-garage.com/trans_pre_o7.htm (5 speed = 1-7/8" pulley/sprocket nut)
http://www.georges-garage.com/trans_06_up.htm (6 speed = 2-1/4" pulley/sprocket nut)
http://www.mbsmfg.com/hadato.html
Clutch hub nut (left handed threads!!) socket: 30mm
New 2014 style SE Compensator Torx Socket: T70
Old 05-05-2015, 10:42 PM
AdamM's Avatar
AdamM
AdamM is offline
Interested in this as well
Old 05-05-2015, 10:46 PM
fat_tony's Avatar
fat_tony
fat_tony is offline
deleted
Quick Reply: The belt to chain drive conversion thread
